Enhances code blocks with inline rendering, autocompletion, and more!
| Links: | |
| Maintainers: | ckant |
| Version: | 2.0.2 |
| Minimum app version: | 2.11 |
| Downloads: This version: | 1283 |
| Last updated: | 2026-02-05T08:49:31Z |
Better Code Blocks
Joplin plugin that enhances code blocks with inline rendering, autocompletion, and more
Features • Screenshots • Download • Settings • Credits • License
- Renders code blocks inside the editor pane (rather than only inside the preview pane)
- Adds
copybutton for code blocks inside the editor pane - Autocompletes code blocks
- Changes Select All to select the current code block
- Performs some tricks to prevent accidental deletion of code blocks
- Supports both legacy (CM5) and new (CM6) markdown editor
Download
Search for Better Code Blocks in the Joplin settings under the Plugins section.
| Setting | Options | Description |
| Autocompletion | Enabled, Disabled |
Enables/disables automatic completion of code blocks when Enter is pressed |
| Rendering | Enabled, Disabled |
Enables/disables rendering of code blocks |
| Behavior of Select All inside code block | Select current code block, Select everything |
Changes the behavior of Select All while the cursor is inside code blocks |
| Render layout | Minimal, Standard |
Changes the layout of rendered code blocks |
| Corner style | Square, Round |
Changes the border style of rendered code blocks |
| Copy button behavior | Copy code, Copy code and fences |
Controls what's copied when the Copy Code button is clicked |
| Autocompleted languages (new CM6 editor only) | (comma-separated list) |
Enables native autocompletion for the given languages |
| Excluded languages | (comma-separated list) |
Disables rendering of code blocks for specific languages |
Credits
Copyright © 2023 Chris Kant.
This project is MIT licensed.
