Task manager for Joplin: dates, alarms, recurrence, search and linked notes. Interface in Brazilian Portuguese. Android: enable Joplin notifications. PT-BR: Tarefas no Joplin com datas, alarmes, recorrência e busca. Android: permita notificações.
| Links: | |
| Maintainers: | will444 |
| Version: | 1.1.3 |
| Minimum app version: | 3.5 |
| Downloads: This version: | 649 |
| Last updated: | 2026-04-26T00:12:51Z |
WillDo
WillDo is a task manager plugin for Joplin focused on speed and practical use.
- Create tasks quickly with Enter
- Edit title and date/time
- Native alarm support through Joplin to-do mirrors
- Daily, weekly, monthly, and yearly recurrence
- Search with visual highlight
- Link a task to the currently open Joplin note
- Open the linked note directly from the task
- Separate pending and completed tasks
Typical workflow
- Create the task quickly
- Set date/time when needed
- Link it to the relevant Joplin note
- Let Joplin handle the notification
Build
Run: npm run dist
The generated .jpl file will be created in the publish/ folder.
